Disables MAC address learning from the payload of IP ARP packets.
| vr_name | Specifies a virtual router. |
Disabled.
To view the configuration for this feature, use the following command: show iparp
The following example disables MAC address learning from the payload of IP ARP packets:
disable learning iparp sender-mac
This command was first available in ExtremeXOS 12.4.
